		Dean Taylor
Well Dave...if you are reading, it doesn't look like the leak has anything to do with the Compression post. All is well there ...dry as a bone on both tacks and under power. Seals are secure and dry.Seem to have confirmed the leak is under the cabin floor as can see the water slosh around on both tacks, down the side of the ballast valves. I can see it with a flashlight also when a person lightly bounces on the teak floor. Water is the same red or brackish color as I've been getting in the bildge. I guess the question now is...."Can the floor of the H26 be taken up? If so how?Has anyone done it."By the way I also checked all through-hulls closely and there doesnot seem to be a problem. Does not appear to be anything that may have punched a hole in the tank either. Any input will be appreciated.Regards:   Dean
