Ball Mount Height for H170 w/ Venture Trailer
sean33
Jan 24, 2005
11
Hunter 170 Sayville, NY
Hi Everyone, I just purchased an H170 with a venture trailer. I will pick it up next month. In the meantime I need to get a hitch and ball mount for my 2000 jeep cherokee. Does anyone have an H170 with a venture trailer and if so, do you know the hight of the ball for a level trailer? I need to figure out what drop/riser size I need for the ball mount. Thanks in advance.
Feb 27, 2005
4
Hunter 170 Rochester NY
drop/riser size
Sean, Regardless of the trailer make, measure from the ground to the top of the hitch box opening. Then, with the trailer level, measure from the ground to the bottom of the receiver on the trailer. The difference is the rise (or drop) height. You'll find this information at the web sites of various hitch manufacturers and retailers.
sean33
Jan 24, 2005
11
I don't have the trailer yet.
Hi Rick, thanks for the response, but I don't have the trailer yet so I can't take a measurement on the trailer - only on the hitch. That is why I was asking if anyone already had one if they could measure their trailer from the ground to the ball reciever with the trailer level. -Sean
Feb 27, 2005
4
drop/rise
Sean, I should have read your first post more carefully. If you don't hear from a Venture/170 owner, maybe the dealer or seller can tell you the receiver height. Good luck, happy sailing, and pray for an early spring!
CarlG
Feb 19, 2005
4
- - South of Boston
Just got my 170 w/Venture
I called Venture before I went to pick up the boat. Venture said 17". Hope that helps. Carl.
sean33
Jan 24, 2005
11
To bottom of receiver or inside top of receiver
Hi Carl, Thanks for the reply. Is that 17" to bottom of ball receiver or to inside top of ball receiver? The difference could be 2-3 inches depending on ball height. Thanks, Sean
CarlG
Feb 19, 2005
4
- - South of Boston
To the Tongue
When I called Venture, they didn't really specify. I guessed to the tongue, because that's where the trailer "rests" once it's on the ball. I went out )in the cold) this AM and remeasured just to make sure I remembered correctly, and it's 17" to the tongue. I have a stock Hidden Hitch that came with the riser for my Mini SUV (Honda CRV), and 17" is exactly where the riser that came with the hitch was set, so this might be some kind of standard.... Carl.
