Bad Weather for Sailboat
Jun 21, 2004
3,055
Beneteau 343 Slidell, LA
As you are aware, we have had some nasty weather along the Gulf Coast with cold fronts moving thru every few days. Have to wonder whether the crew was up for the conditions or if the rigging was suspect.
Likes: JamesG161
The image of the boat shows that the mast and rigging were damaged. What is curious is that they are abandoning the boat.
Cutting away the standing rigging and mast, saving the running and mast part, permits you to use the sail draped over the deck to sail downwind to a port. It looks like there is a dinghy. Does it have an outboard? Is the inboard auxiliary engine running? The boat does not look like it is sinking, as the water is at the painted waterline.
It sure appears that the crew was not up to the challenge of saving their boat. Now the boat sits out on the open water 40 miles from Florida. Drifting on the water til someone salvages it or it hits something. :yikes:
I had the same thoughts..... I'd love to have a boat like that and I'd do every reasonable thing I could to keep it if I got in a similar jam.
Nov 8, 2007
1,610
What jssailem said.
Clearly, the crew were overwhelmed by the dismasting and couldn't develop and implement a recovery plan of their own. I speculate that physical limitations and ignorance may have deprived them of the resilience to overcome a failure.
At 80, we have decided to sell Lady Lillie, and sail less with more support on chartered boats.
