Steve
I recently purchased a 1992 H28. During sea trials, I noticed a vibration when running the engine in gear (forward and reverse). Since the purchase, I have had the propeller reconditioned and pulled the the prop shaft in preparation for replacing the cutlass bearing. The shaft is bronze and is showing a little wear in the stuffing box and cutlass bearing areas. I had to drop the rudder to get the shaft out and I don't want to put a "bad" shaft back in. The engine alignment seems to be OK - or at least isn't noticably out of alignmnet to my eye.My question is, how do you know when the wear is excessive and the shaft needs to be replaced?? Is it possible for a shaft to be perfectly straight but be out of balance and cause vibration??Thanks.
