I'm sure the boat has a holding tank?
And since you're new to boating, you prob'ly don't know that you have to use a product in it that prevents odor. Or you may be using one that doesn't work, just adds a chemical odor to the sewage odor...there are a lot of 'em on the shelves. Buy a product called Odorlos http://www.odorlos.com available from marine stores and RV supply stores (the price is lower at RV stores). Pump out and rinse out the tank, then use it according to directions (according to directions is VERY important!)Also make sure your tank vent is clear...check the vent thru-hull. If you don't know where it is, trace the small hose coming off the top of the holding tank to the hull. Scrape out anything you find. How old is the boat...or more specifically, the toilet? Also, what's the brand of the toilet?Finally, I suggest you check out the link below...it'll take you to a comprehensive "marine toilets and holding tanks 101 for dummies" manual that'll help you learn how to operate and maintain your system.
