C
Colin
I have a bad ground wire in my mast, as a temp fix I am using the mast to ground the mast lights. My question is how do I get at the wiring at the base of the mast from inside the cabin? The boat is a 1989 Hunter 33.5? What I believe is the compression post is glued and screwed together and I don't want to take that apart as I might split the wood.
