Bad Elf or Dual
25
Catalina 30 mk1 Horseshoe Bay
Hi all. I have been using Navionics with my iPhone and I now have an iPad that I thought would be useful for navigation too. The problem is that I don't have the iPad with a built in GPS. So I need to buy a receiver and I was wondering if anyone has tried the Bad Elf or the Dual receiver. By the way, these are just back ups to my Garmin handheld - that has a very small screen and isn't as nice to look at as the iPad.
Thanks,
Rob
961
Macgregor & Island Packet VENTURE 25 & IP-38 NORTH EAST, MD
I use the Dual for my ipad. Works fine and has good battery life (will outlast the ipad). And there is an app, that gives you a lot of good info on your Puck (batt life, position, sats used, ). Don't know about the Elf.
jtm
Jun 14, 2004
314
Hunter 28.5 Dataw Island, SC
I'm at same process as you- recently got an ipad2 and plan on installing inavx( check out the apps review on Practical Sailor recently). I considered the Bad Elf and the Dual. I like the bluetooth approach price differential aside) as I can mount the dual on the ped or a cabintop rail or dodger rail and have it handshake to the ipad via bluetooth.
What I see about the Bad Elf plug-in to the ipad ( which i would use in the cabin for planning/mapping purposes) is a degraded sat signal , and more importantly - the plug-in to the bottom socket of the ipad is just begging to be broken off in an unfortunate movement. I think Dual xgps150a (bluetooth) is the easy choice!
Sep 2, 2009
339
Hunter Vision-32 New Hamburg, NY
I've got the Bad Elf bluetooth .. works fine with my iPad 4 ... nice standalone features too
961
I keep my Dual puck down below on the table and can bring the ipad out into the cockpit, and have never had a signal problem (satelite or bluetooth). But my boat is small, you guys with larger craft may have differing results.(ok no jokes here)
Nov 9, 2008
1,338
Bad Elf had a pretty decent write-up in Ocean Voyager mag. If I didn't hate Apple so much, I'd probably pick one up myself.
Nov 24, 2012
586
Panbo.com is a great source for anything concerning electronics. I know Ben has reviewed bad Elf not sure about dual.
Mar 6, 2011
25
Hey you guys are great. I was wondering about the durability of the Bad Elf. Now there is a Bad Elf Pro. Just when things seemed so simple! I may just go with the Dual.
