Tom M. That happens to a lot of masthead boats
with Larger genny's. Especially when hard on the wind. I understand what Don is suggesting but I wouldn't ease the jib sheet if it now caused the jib to be improperly trimmed and the tell tales are not streaming well.I was on a custom Tripp 37 doing the around Block Island Race and asked the skipper about that. He says don't worry about it too much, and especially don't try and adjust things and overly flatten out the main or let out the genny too much to get rid of it. Just trim your sail as you normally would.The biggest power on your boat is in the Genny, so get the Genny trim perfectly and tell tales streaming well and then adjust the main sail so all the tell tails on the leech of the main sail are just streaming and the top one just fluttering. I think you will find your speed best there even with the bubble. I have read that the mainsail on our boats can be looked at as more of an "afterburner" and the slot can actually increase the speed of the wind going over the Genny. I have also heard its the wind speed at the aft end of your mainsail that matters the most for the best speed and I think the bubble usually shows up in the front of the mainsail. (Obviously you don't want to "choke" the slot and you have to really play with them to get them working together).I don't have the complete answer-it really depends.But if the bubble is really big I'm sure it can effect your speed. From a North Sails site it says"If you have a lot of backwind, chances are your (jib) lead is too far forward. Slide the lead back and monitor the backwind. It may never go away, but it should help ...."Another sail maker says "At this time the front of the main will have a large bubble in it, caused by the large volume of air exiting off the leech of the genoa. This is known as backwinding the mainsail. It may look awkward, but it is the fastest arrangement given the constraints. If we look at this same circumstance using a full batten main, the battens will prevent the bubble from forming in the luff, essentially forcing the mainsail down into the high speed exhaust flowing off the jib. This is now constricting the air flow, essentially acting like an air dam, preventing the air from exhausting off the leech of the jib. This will be a performance liability...but it will "look better." http://www.pineapplesails.com/articles/fullbatt.htmHere are some other discussions on this.http://www.setsail.com/c_central/sail_advice/sail_advice.html#optimum
