Del Wiese
I have a split backstay and want to add a backstay tensioner. The upper is 9/32" 1x19 wire, rated at 10,300 lbs. The bridles are 1/4" 1x19, rated at 8200 lbs. I can't find info on the bend radius of 1x19 (or 7x19 either) but intuitively I think it is much greater than any block used for the tensioner. On previous boats I've used 7x19 for the bridles and had no problems. In order to match the current bridle rating, I will have to use 7x19, either 9/32", rated at 7800 lbs, or 5/16, rated at 9000 lbs. The problem is that I can't find any wire rope blocks that will accept more than 1/4". Has anyone solved this problem, or am I missing something?
