I have a 1992 Catalina 28. As typical on that particular model it does not have a split backstay. I do not have the manual for my boat and I am curious as to what tension should I have the backstay set to. It seems that if I tighten it even slightly to much my mast seems to tilt slightly to starboard which is the side that the backstay is attached to the stern. Does anyone have any suggestions?Thank you
