removehtml]I reciently bought a Catalina 270LE. The split backstays were pressing on the outboard side of vertical membors of the sternrails (port and starboard). I moved the backstays to the inboard side of the sternrail posts and they are better but still touch. Is this a common problem? I'm considering adding a backstay tensioner to pull the split backstays closer together. Is there a simpler solution?Error: Error: expected [/URL], but found [/removehtml] instead[/removehtml]
