Backstay adjuster for a beneteau 311
Aug 20, 2013
185
Beneteau 311 Port Clinton, OH (Lake Erie)
My Beneteau 311 has a conventional turnbuckle on a single, 3/16" backstay. Much of the job of holding the mast aft is done by the swept-back upper shrouds, but I'd like to be able to tension the backstay for windier days. To adjust it now, I have kneel or sit on the transom swim platform, undo the cotter rings, adjust the turnbuckle, and redo the cot ter rings. That's usually too much to do underway and a hassle even at the dock. Has anyone on the forum installed an adjustable backstay device on a similar boat, and how did it work out?
Nov 8, 2010
11,386
A boat that size will need at least 16:1 purchase to be effective. That means a 8:1 block set with a 2:1 ring to make the 16:1.
You boat has one hard point on the transom for a backstay. You COULD make the 2:1 work off the same point, or you could add two hard points wider on the transom, and use the middle for the lower 8:1 block. That would be better. In any case, you would shorten your existing stay, and add a stout block to the end. A loop of Dyneema up and over makes the 2:1. Them comes the 8:1. The image below shows a 16:1 made from 4:2:2:1, not 8:2:1. You could do it either way.
You only trick will be where to adjust it; our First 36.7 uses a remote adjuster. The cleat is not on the block, but by the mainsheet lead by a series of turning blocks. A bit of work to set up, but much nicer. For your needs a simple cleat on the block should work fine.
Aug 20, 2013
185
Jackdaw,
Thank you for your response. I figured a block and tackle would be the simplest and most direct. Unfortunately, the backstay is attached to base of the "sugar scoop" style swim platform, and its structure is not visible. It's a few inches thick. There's no way that I can see to get inside to attach nuts and backing plates. But maybe something was set up in advance during construction.
How did you determine that 16:1 would be sufficient purchase? The breaking strength of 3/16" wire is about 4000 pounds, so I probably won't want to put more than 800 pounds of tension on the backstay (20% of breaking strength), and maybe not more than 600). Not counting friction, a 16:1 purchase would mean I would have to pull 38 pounds to get 600 pounds of tension, which is probably as much as I would want to pull.
Maybe a set of blocks for a boom vang would work. These setups often have an offset as part of a single block and tackle arrangement.
11,386
Jackdaw,
Because 8:1 would be way too hard?? ;^)
Maybe 12:1, but I bet you and crew will be much happier with 16:1. Now with some care, you can make a cascaded system from one lower point. Choosing small hardware helps (like low friction rings in place of blocks), and you can also use a triangle plate at the bottom to create some separation.
Like the new Sunfast 3600 does.
Aug 20, 2013
185
Jackdaw,
The triangle plate is a good idea.
On my question of how much purchase is enough, did you suggest 16:1 from experience, or calculate it somehow? Is 16:1 enough, or maybe 24:1 (8:1 with 3:1)?
I emailed Harken, but I didn't get a very thoughtful answer. They suggest a hydraulic tensioner, which would be $1500, overkill for what I need.
Nov 8, 2010
11,386
Jackdaw,
Mostly from experience, with a quick calculation like the one you did as a sanity check. Too little or too much will work, but its either harder and you have to deal with too much line. Its also what you can make with with the hardware you choose or have available. 24:1 would work great, but probably as 6:2:2:1
Also factor how much you will adjust it. Skip the hydraulics.
185
Does anyone have a comment on the type of adjuster shown in the attached picture? It is a turnbuckle with handles that close to lock the turnbuckle, and open to allow hand adjustment. The vendor says it is the right size for this application.
The pins may not fit the swages I have. I'll have to check that, and maybe add a toggle.
11,386
No enough range. And way to slow/hard to adjust.
Unlike shrouds that get adjusted +/- 5 turns across the entire wind range, you pull the mast tip back several inches to effect trim. And on a fractional boat you do it a lot. You'd be turning that for hours even if the range was enough. On masthead boat you used to see a big wheel that was rotated on a long screw, long enough to have effect. You don't see those anymore, and never on fractional boats.
Rick D
Jun 14, 2008
7,186
Allow me to butt in here with a question. On previous boats with standard 90 degree spreaders, I added backstay adjusters. However, with my fractionally-rigged Hunter Legend 40.5 with swept back spreaders (but not a B&R), I was told by my rigger that it wasn't a good idea since adding tension would have the effect of loosening the shrouds. Thinking about the geometry, that made sense to me. However, a friend who raced his 35.5 very successfully with the same rig used one regularly. Comment?
Nov 8, 2010
11,386
You are correct, on a fractional boat tightening the backstay:
Tightens the forestay
Bends that mast
Loosens the shrouds
The amount that is loosened can be known and factored into any rigging setup. On our boats, when we know we will be sailing in big breeze, we tighten up the shrouds to the max; 24% of breaking strength with backstay slacked. Putting on max backstay will loosen them to 20%
For boats that use just one general setting, I'd suggest checking the shroud tension with backstay full off, and full on positions.
Aug 20, 2013
185
Jackdaw,
I hadn't thought of the range thing. I was thinking of the shrouds and their range of adjustment is about 8 half turns up or down (on each side). On the backstay I put on 8 half turns and it seemed to help flatten the main, starting from 200-300 pounds of tension (the upper shrouds are set at 21% of breaking strength), but I probably added only 200-300 pounds. I don't plan to do much buoy racing, so I won't need to adjust the backstay often, maybe once or twice a day.
The Beneteau 311 mast is something like a 19/20 fractional rig, so the top of the mast won't move as much as on other fractional rigs, such as a J29, but will probably move much more than a masthead rig.
The wheel adjusters are about half the price of the hydraulic adjusters, but the prices are closer on e-Bay (used/rebuilt).
This thread is a good discussion of the different options and why. Thanks for your ideas and thoughts.
