Plexiglass - Perplexing
Drew, I don't doubt your word, I haven't owned a Pearson, but I've sailed them, and they are well-built.Plexiglass is a strange material for 'backing plates'.stainless, or even aluminum, if it is against the glass, is normal, or even good sized washers. Wood filler, like a tapered hull-shaped piece to 'fill' the space for a thru-hull. even ply beneath a windlass, with heafty stainless plates to suck up against the ply whence the stainless bolts are tightend up to nylocks or doubled lock nuts underneath. The Idea is OVERKILL, you cannot make it too strong, and you may one day use your jib winch to pull yoursel out of the mud, lotta physics involved thar...
