Backing plates
Gordon
Apr 30, 2009
40
Beneteau 473 St. Petersburg, FL
  Someone mentioned stainless backing plates when mounting turning blocks etc.  I prefer 1/4" poly for backing plates. It is tough and not brittle. It is easy to cut to desired shape with a jigsaw.  Easy to drill. It doesn't corrode. And it is cheaper.  And lighter.  Where do you buy it?  Go to the kitchen section of your favorite Wally World and get a poly cutting board!   Gordon
Oct 19, 2019
921
Albin Vega 27 Limerick
I've used marine ply but my wife wouldn't notice a missing cutting/chopping board.
Genius! :)
Sent from TypeMail
Sent: Tue Dec 22 17:13:25 GMT+00:00 2015
To: "AlbinVega@yahoogroups.com"
Subject: [AlbinVega] Backing plates
Gordon
Sep 24, 2008
346
I think a better backing block is made from garolite or G10, attached with epoxy. This actually makes the area stronger and is not just a stop so the nuts do not pull through. Epoxied plywood works as well. The plastic you are referring to is not a good choice as it creeps under load. Stainless or aluminum cannot be epoxied in place.G10 has greater compressive strength than steel or stainless steel.
