Backing Plate for Cleats?
Bruce
I want to install two additional cleats on the bow of my 23.5, to ease the "traffic" on my one factory installed cleat. I opened up the bow section and saw that I have space on either side of the anchor locker to install a backing plate about 1"x6". I was thinking about getting a 1/4" steel plate to use. Any suggestions/coments? Thanks for the assistance. Bruce H23.5 "Off Call"
Pete
backing plate
You are on the right track only suggestion I have is that is backing plate be Stainless steel or aluminum not steel (rust)
Rick Webb
Let us know how it turns out
I have looked at the same thing and thought of using a couple peices of preasure treated 1X6s with fender washers on the other side. I am also planing on doing that for the U bolt in the anchor well as I do not like the way it flexes when the mast is going up.
richard
get good stainless
get good stainless!!you want 304 stainless steel. nothing less. use good stainless hardware to bolt thru and the same for the cleat. spend the $ because the alum. will turn your lines black. also, there will be a galvanic response [rust] if you mix metals. I have used varius types of sealants but any time you go through glass or coreing with new hardware i use 3m's 5200. just don't put it on when it is too hot or in direct southern sun in summer. hope that helps...rich
Dave Condon
backing plate
Definetly use a backing plate of sorts or you could rip out the cleat. Pete's advice on metals is right on. thank youpete. Crazy Dave
Bruce
Options?
Thanks for the advice so far. I looked at stainless steel (Boat U.S.) and the stainless cleats require 4 fasteners (set in a rectangle shape), I don't think I will have room to mount a backing plate wide enough to support that. I saw some cleats that were galvanized steel and some that were aluminum - both of these will require only 2 fasteners - this is very "doable". Outside of the potential to color a line black (see previous response), will I have any problems using either the galvanized steel or the aluminum? FYI - the boating store in my area doesn't carry backing plates, I will be getting them made at a machine shop (about $5 each for 1x6x1/4"). Thanks for the suggestions. Bruce S/V "Off Call"
Dec 2, 1999
15,184
Bruce
Bruce: Bigger is better with these backing plates. 1" wide seems a little small. The idea here is to distribute the load over the largest possible (practical) area. If you can swing it I'd have these plates 2-3" wide. Obviously if there is not room then this is the best you can do.
