OK, lets start with this first truth in hindsight I did something stupid. It won't be the first time and it certainly won't be the last so some thoughts and input to prevent at least this same issue would be helpful.
This particular stupidity started with an engine problem but was not caused by it. I bring it up only as a point of reference for why I may have done something this stupid or if nothing else would not have found myself in this situation.
I was sailing from Middle River to Harve de Grace for a solo overnight, something I had not done before, had been their twice before but with my more experienced friends as crew. Have been only sailing five years and only have owned a boat big enough for this the last three.
With the wind near nothing the second half of the day I gave in and turned on the engine, which ran beautifully till it didn't. Thought I knew the problem had the parts but it was getting dark, my destination was still about 6 miles away and while the wind was piping back up and coming from a useful quarter I decided it would be smarter to deal with the engine in daylight and not push my luck with the narrow channel with out the engine as backup. Perhaps that and fixing the engine were the last two smart things I did.
I didn't get much sleep that night as I was anchored just out of the channel and lots of speedboaters came by late that evening, then I discovered that while I had let out enough scope, it was enough that when the wind shifted I blew into a batch of crab pots so I had to shorten up the line. Then I was thinking about the repairs.
In any case got to Harve de Grace and that is where the stupidity kicked in. My Hunter walks heavily to port in reverse. I need lots of room to back into a slip. After three attempts and no clear sign of how I was going to do this I gave up and pulled in nose first. First mistake. Then I tied up got a nap and went out to wander town. Came back aboard and went to bed, woke up around 2 in the morning realizing the wind had come up and shifted and I was now hitting the finger pier. Got dressed and went up top to adjust the lines. Checked the forecast and discovered that the weather was going to be ok in the AM but go down hill fast after lunch. Spent much of the remainder of the night not sleeping trying to figure out how to recover my dock lines and get out of the slip. Second mistake, should have stayed put till later when I could have had help but decided I knew how to get her out and left the slip about 6 AM, got out and got clear but the prop walk was making her hard to keep clear of the boats along side of me. Wind was coming out of the east and I was backing right into it. Now in the fairway I found that no matter what I did could not get enough speed to gain steerage to keep off the boats on the lee side. I quickly came to rest on the bows of the boats on that side. Won't bore you with more details but suffice to say bad as it was I wasn't damaging them or my own boat and I made my third mistake continuing to try and get the boat free. If I pushed the bow off the stern got pushed onto a boat behind and the opposite if I pushed the stern off. Eventually several people sleeping aboard heard this came off and rescued me by pushing me off at either end.
As I say I should have stayed where I was and asked the marina to help get me out, either by towing me out or by putting a few people aboard to help fend off till I could get her clear which I could have then dropped at the fuel dock.
But the question is if you have made the second mistake and pulled out of a slip and found yourself unable to control the boat and not able to get back in and resting on other boats while you are alone are there any ways to get yourself out of this trouble or are you doomed to look like the fool you are and just have to wait to be recused. Looking back I realized I might have been able to kedge the boat off by using two anchors, one front one back and walking her away from the other boats but I am not sure having done that that I would still have the same problem the Second I tried to lift the anchors and the bow or stern swung back to the lee.
By the way there seemed to be no damage to anyone but my boat, I broke the weld on a stanchion which leads to a second posting I will make in the Cherubini section of the Hunter forums.
