C
cat30owner
Recently I have run into a problem and need others help. I have changed my slip to a non liveaboard but it is a down wind slip. I did not figure in the differences and went about it in the same manner. I figured I would pass the slip slowly in reverse and then safely back in to starboard. Not what happened.As the boat slowed the bow being pushed to starboard and the prop walk pulling the stern to port made for a sticky situation. When the boat finally started in reverse I did not have enough room to back safely and turn. When I finally was able to back up I found that the wind at the bow on the port side would not allow the stern to turn to starboard well enough to straighten the boat before putting a nice dock streak on the starboard beam. How would you go about this maneuver? I know it will take practice but before I practice I would like to hear how others do this. Thanks alot, John
