Back in the water...
134
Hunter 170 Lake Sammamish WA
Today (May 30th) I launched my 170 again for the year. I have a buoy in front of my home which is very handy when the whim to sail comes up with the wind.
The "good" is that I only have to setup once a year. The "bad" is that I find I make mistakes in setting up because I just don't do it that often. If memory serves me right, this is only my 4th time to step the mast.
I thought I had everything I need so I drove to the boat launch on our small lake (about 3 miles away). In getting my gear our of the truck, I realized I had left the boom back in the garage. I briefly considered going ahead with the launch anyway and putting the boom on later along with the mainsail, but the wind was just too inviting. So, it was all gear that I had taken out went back in the trunk and then back to the house for the boom and then back to the launching ramp.
With my Johnson quick releases on the shrouds, I was able to get the mast in the footing very quickly. Then the old 50-50 problem that I have reared its ugly head as I was getting ready to attach the jib before the stepping. On a 50-50, I almost always go the wrong way. Somehow, I grabbed the wrong end of the jib to attach to the upper mast. The only problem other than trying to attach the wrong end was that all I saw was a round ring and NO way to attach it to the mast. When I take down the mast or anything else, I ALWAYS leave the fittings, clips, rings etc attached so that it will all be there in the spring. FINALLY it dawned on me that I had the jib upside down. From that point on, it was easy to attach the jib and then step the mast, but I wasted about 20 minutes in trying to do it backwards.
The rest of the setup went quickly or as quickly as I wanted. I would have be ready to launch in about an hour, but with the 20 minutes I wasted, I was ready to float off after 1 hour 20 minutes. Never make that mistake again.
One thing different on my setup this year was that I didn't put my 2 HP motor on until after the mast was stepped. In the past I found that the shrouds can get hung up on the motor if it is attached to the boat while stepping the mast.
After the launch, I had a great first sail of the season back to my buoy. Next year I'm going to have a checklist to make sure I don't forget anything like today's missing boom that I had to go back for.
At 73 years of age, I wonder how many more years of sailing I have left? What I really mean by this is how many more years I'll want to get involved with this mast stepping procedure and all that goes along with it. It's a piece of cake sailing off my buoy and back on to it, but the solo setup/take down is another matter. Thankfully, I only do it once a year. Almost every weekend, I see another Hunter 170 beating up the lake. The 2 guys on it trailer the boat in and out every time they go out for a sail. I've watch them and they can do it in 15-20 minutes. Wonder how many other 146/170 sailers have to rig up every time they go out?
ddeand
Oct 12, 2010
33
Hunter 170/18 Everywhere
I'm glad you were able to get back on the water again this year, and I hope you can find some help getting the boat on and off the water for the next 20 years. I do the same as you - I have a buoy and only have to do the setup and take down once each per year. I leave the jib on the mast and hang it all up in my garage - so far, no problems. I can do everything myself except get the jib pin into its hole, so I usually ask a passerby to slide the pin in as I pull down on the jib/forestay.
You've got nine years on me, but I hope to be able to do what you're doing when I'm 73. Glad you got the boat in and ready to go for the season!
Have a great year!
Dean
Oct 8, 2009
134
ddeand...
Smart idea about leaving the jib attached to the mast. You must have a LONG garage. Re attaching the jib pin, the first time I thought I would NEVER get it in.
However, it's a piece of cake now. First of all, I have the Johnson quick releases on the shroud cables. That does 2 things. First, it gives me about 3 extra inches when I'm trying to get the mast in the step. When stepping the mast, I have a line from near the top of the mast running to a pulley on the front of the trailer (top of the mast support). While I'm stepping the mast, I pull on this line. When the mast is upright, I temporary cleat the line on the mast (securing it from falling backwards while I get out of the boat to attach the jib pin).
Now with the Johnson quick releases STILL open, when I go to the front of the boat, I'm guessing the jib attach point has about 5-6" of extra length due to the line to the pulley pulling the mast forward while cleated, making it very easy to slip in the pin.
In case you didn't see one of my previous posts, the line I'm referring to is the "red" line in the picture. When I'm finished stepping the mast, I simply cleat the line to a open cleat on the left side of the mast. While I've never had to use it as such, I think the line might come in handy if I ever had a knock down.
lokiii
Apr 12, 2010
30
Hunter 170 SLO
"Wonder how many other 146/170 sailers have to rig up every time they go out?"
Every damned time, most weekends, all year round. It's getting old. Takes me about 25-30min by myself. I'm envious of you guys who can park a boat for the summer.
Oct 8, 2009
134
There is a downside to "parking" a 170 on a buoy, at least on my lake. And that is an awful brown tinge that builds up on the hull over a full season, resulting in either a very messy clean up on haul out or just before going back in the water for a new season.
Last fall I was lazy and decided to put it off until now. Big mistake as I think the tinge "hardened" over the winter.
Local natives call it Lake Sammamish slime.
ddeand
Oct 12, 2010
33
BlueRunner,
Thanks for the tips - I also have a line that runs to the top of the mast that I can use to pull it forward. And the quick releases sound like a great addition. And I agree with you about the gunk on the bottom of the hull - last fall, it took me a long time with a power washer and some muriatic acid to get the hull clean. This year, I'll get it into shore and tip it sideways and clean the bottom one halfmat a time - maybe try that twice a season.
I was able to launch my boat today and get it moored for the season - my son came over and helped me so it was pretty easy going. We had a nice breeze for the first sail of the season and no one perished!
Dean
