I have a 2008 B43 and have a leak under the prop shaft where it exits the boat, it is not coming from the volvo seal, that is high and dry. The water (salt) is seeping up from the area under the shaft, it fills the small recessed area after a day. I have read some posts on issues where the intrusion is coming from where the shaft exits into the water. Any advice or ideas would be appreciated.
Thanks
Thanks
