B361 Water build up under engine when running
3
Hi I have water build up under the engine when motoring long distances its dry all other times. It has a Volvo drip less shaft bearing. It seems to fill all three of the chambers equally. Any similar experiences, thoughts ??
Thanks,
Jay
Nov 23, 2009
437
Beneteau Oceanis 361 Clipper --
Salt or fresh water?
If salt is the volvo drip less indee dripless?
What about the vended loop? Is it working properly?
What about that nipple bringing in water in the shaft? If it has failed be very careful. Don't touch it or move it. You will need to lift the boat out of the water to fix it.
Jan 2, 2009
36
beneteau 323 Riverside NJ
Water Buildup on long trips
HI:
If it is a Yanmar engine, I was seeing a small water build up and while I was checking the move obvious, I finally changed out the water pump and now everything is fine. Note the water pump did not have that many hours on it, certainly less than 250hrs and I would have figured that it would have lasted much longer. Towards the end of this problem the water pump actually seized and I pulled it off and was able to free the turning of the pump so that all seemed fine and the engine ran with no problem. However, after the seizing occurring, I did not wish to take any chances. All the above, for what it is worth.
Rick I
Jan 6, 2007
414
CS36Merlin and Beneteau 393 - Toronto
Check your vented loop in the cooling water. Clean or replace the Vetus vented
vented loop. This is the most common cause of sea water under the engine in Beneteaus.
Nov 24, 2012
3
Thanks to all
Thanks for the response. It is salt water and its a Westerbeke 30B. I will check out the vented loop. and let you know how I made out.
Jun 6, 2004
8
-Beneteau -331 Rock Hall, MD
I have a 30B on my 331. I had a similiar leak and it turned out to be the raw water pump. It was a small drip that evolved into a big drip. It only leaked when the pump was running. It was very hard to detect. Check for it dripping when your motor is running. I had to replace the pump.
Cwoody
Aug 10, 2010
87
Beneteau 37 Galesville, MD
Same thing happened on my 331. Previous owner had replaced the impeller just before I bought the boat and did not tighten the cover screws down completely. Took a while to figure it out because it did not leak with thru hull closed. Flash light check of engine while running and the leak was very obvious.
luken7
Aug 21, 2010
96
Beneteau Oceanis 361 Oriental
I had the exact same problem driving me nuts for months and it turned out to be that the Ventus vented loop needed cleaning. I just happened to come across the bulletin a while back and that was the problem.
