B361 leaking aft water tank
David Kilmer
Has anyone else had a problem with the aft water tank cracking on the B361? And if so, how did you fix it? The crack developed inside the hollow section through the middle. The replacement tank from Beneteau is larger, and just wide enough that it doesn't quite want to fit. I see four options: 1) Try to plastic weld the old tank. 2) Try to find an intact tank from a 2000 B361 for sale 3) Custom build a tank to fit 4) Modify the aft bunk - raise it up to allow the new tank to fit. I'm leading toward #4. Anybody done this before? Any other ideas? Dave Kilmer Liberte dkilmer@usa.net
C
Charlie Gruetzner - BeneteauOwners.net
Leaking water tank
Dave, I had the same problem with my aft tank. I filled it with water took digital pictures of the leak and sent them ato Todd Cranston at Beneteau. They repalced the tank for me at no charge. It is a little different in size but it still fits . Good Luck Charlie
