Evening all. I've been searching across the web regarding the Volvo shaft seal and the need to grease and burp it annually. I'm finding varying responses from not needing it to must do it. Today, we have a slow leak which fills the area under the shaft, but takes a while to do it. We'll take the boat out for the weekend, and it seems to fill up quite a bit to the point that it runs over to the area under the engine, but takes several days to do so. I'll leave to go back home and when we return the following weekend, it's full. Bu it doesn't fill up right away, takes several days after we're gone. Any comments would be appreciated.
Also, from the picture attached, wanted to be sure we're talking about the same seal.
