Auxiliary Main Halyard
Nov 10, 2012
62
Catalina 36 mkII Havre de Grace, Maryland
I have a 1980 Hunter 30, and would like to add an auxiliary main halyard to the mast. Has anyone done this? I'm assuming I need to add another sheave at the mast base? Are parts hard to come by for this operation?
-Thanks in advance!
May 27, 2004
2,055
Ed, I rehabed my 79 H 30 mast head and looked for sheaves everywhere with no luck. My boat was not built with base of the mast exiting haulyards. But since my mast head had the extra sheaves for a topping lift and spinnaker built in for a total of four, I thought the '80's models had the same number of sheaves at the base.
Nov 10, 2012
62
Thanks GGrizzard. I'll be stepping my mast next month so, I'll see what is available to use on the mast for the aux halyard.
Jun 5, 2010
1,123
Hunter 25 Burlington NJ
A vote for double halyards
Your easy solution for this would be to install an exit block (up-side-down) at the top of the mast, which might be slightly off-center but would suffice for the purposes of safety/redundancy. This line could be led down inside to another exit block (right-side-up) at the base of the spar for the halyard. Storm trysails are often fitted with such a setup.
The slightly more difficult solution would be to replace the masthead sheave box with a double-sheaved one. I did this on my boat. The part was readily available from Dwyer Aluminum Mast Co in Connecticut, came complete, and was surprisingly inexpensive. I widened the slot in the spar and seated this thing into place, drilled it out for the upper-shrouds' through-bolt (actually a pin-- it should not have threads in the bearing area) and now have double halyards for headsails and main. In addition, the double-sheaved box includes a bail for spinnaker and a pin for a (fixed type) topping lift, which could easily be made to hold a block and an external halyard, so that would give you a whopping 6 halyards from the masthead. (I also have an internal pole lift that will function as an inner-headsail halyard as well.)
Even when you have a roller furler, the addition of a second line for some option or redundancy makes sense. The single headsail halyard that is used to hoist and tension the roller-furling headsail gets so little 'exercise' that it very commonly fatigues at the crease atop the sheave. Being able to exchange this duty with another piece of line sometimes will enable you to inspect the last-used one as well as to keep sailing if one of them gets too far worn.
I applaud anyone going to a double-halyard setup, as I consider a certain redundancy in this area absolutely vital to anyone seeking some insurance from losing a halyard. If I may impose a traditional standard, code the halyards as follows:
Headsail halyard #1 (primary)-- port sheave, red fleck
Headsail halyard #2-- starboard sheave, green fleck
Mainsail halyard #1 (primary)-- starboard sheave, green fleck
Mainsail halyard #2-- port sheave, red fleck
This follows what was always done in ages past and intuitively makes sense to anyone who hasn't been taught any other (contradictory) system.
(I didn't get green-flecked line and substituted blue; otherwise my setup follows this.)
Jun 2, 2004
5,802
I thought your mast was the same as mine, four sheaves at the top. I use the port/aft sheave for a spare halyard. It is attached to my topping lift for control of that. But it can always be released and connected to the main. Also useful as a security line when climbing the mast. I simply added an exit plate about twelve inches above one of the mast cleats. Or maybe I added the cleat too, so long ago. But do not feel any deck blocks are necessary for a spare.
Nov 10, 2012
62
My mast should be un-stepped by the weekend. I'll take inventory of the sheaves (top & bottom) and come up with a plan.
