I am going to replace my old Raymarine ST4000 wheel pilot with the newest version X-5 (SPX-5 p70). Just wondering if anyone has made the same upgrade and was able to use the old cables/wires? This would surely save some installation time. Thanks.
I know that you can use the old cables with the 4000 plus. In fact Raymarine will sell you the additional components to convert the 4000 plus to the X-5 for significantly less than the cost of the X-5. They do require that you send them the existing control head. I did this on my previous boat. I would suggest that you call Raymarine tech and ask them.I am going to replace my old Raymarine ST4000 wheel pilot with the newest version X-5 (SPX-5 p70). Just wondering if anyone has made the same upgrade and was able to use the old cables/wires? This would surely save some installation time. Thanks.
Last year I upgraded from my A4000S to a new X5.I was able to install mine relatively easy. Depends on what you mean by using the 4000 wiring. The X-5 uses a control box which the other didn't. Really the only cables I reused were the Seatalk pretty much everything is new. The X-5 is much nicer. I love mine. I was in a seminar yesterday and the Raymarine rep said they are no longer servicing the old 4000 models. Once they break they are gone.
Enough to make me not buy their products.I was in a seminar yesterday and the Raymarine rep said they are no longer servicing the old 4000 models. Once they break they are gone.
I have done a coastal delivery (couple of days, open sea) on an E-32 with a below-decks AP. Powerful and fast... liked it a lot. However that owner got it with the boat courtesy of the expenditures of the prior owner.The X-5 is rated at just over the weight of my boat (Catalina 36 Mark II). Some say if I upgrade from my present AP I should go to a heavier duty AP (under deck). Any thoughts, experience, etc.?
The St4000 was marginal on my Beneteau 361 and was thinking of updating to X5. Eventually I ended up with the below deck raymarine type 1 linear type. It's a different world! Powerful, fast and much much more capable in handling many different conditions (even running seas).The X-5 is rated at just over the weight of my boat (Catalina 36 Mark II). Some say if I upgrade from my present AP I should go to a heavier duty AP (under deck). Any thoughts, experience, etc.?
Should be able to use the old wires except for the course computer as it will be in a different location. This of course providing that the old wires wire sized properly and are in good shape.I am going to replace my old Raymarine ST4000 wheel pilot with the newest version X-5 (SPX-5 p70). Just wondering if anyone has made the same upgrade and was able to use the old cables/wires? This would surely save some installation time. Thanks.
Lou,I replaced my ST 4000 with an X-5 and replaced all of the cables as well. The ST4000 used a control head with a computer in it. The X-5 uses a separate control head and course computer. You need to run a cable from the control head, usually mounted at the helm, to the course computer usually mounted somewhere in the cabin. A cable from the course computer powers the wheel drive motor. The compass has a cable that runs to the course computer. The cable routes are different than the ST4000 so I just used the existing cables to help me pull the new cables through the pedestal.
Raymarine's tech support is not very useful. The X-5 comes with an installation book that refers to a 6000 control head but my kit came with a P70 control head which had it's own installation manual. The X-5 book showed a cable with a plug at the control head and pigtails at the course computer, the only long cable that I had had plugs at each end. When I finally got through to Raymarine the tech support guy said "cut the plug off the end". I said "really, that's the best you can do"?
When I finally got it wired the commissioning instructions differed in each book. The P70 book refers to screens that you can only access if you don't cut the plug off the end of the cable but wire it using the spine referred to in a previous post. It's hard to believe someone can supply a package of components with instructions that are so conflicting. The rational tech support types that I talked to said things like "we keep telling them to change the instructions but nothing happens".
If you lay out all the components and cables on the floor, read the instructions in all the books and make sure you can connect everything together before you start cutting cables or installing things it can be done. Good luck.
