Autopilot/seatalk/gps
rdees
Oct 5, 2011
14
Beneteau 400 Jacksonville
I have a '93 OC400. Recently purchased an Autohelm 7000+ autopilot contol head to replace the 7000 that was not functioning when I bought the boat. Worked fine for a while, but recently stopped working and giving the "seatalk failure" error code. I have new st60 wind, speed, and depth instruments. I checked the seatalk wire connections on each and they appeared fine. Checked connections at the type 300 course computer and they appeared fine. The gps is an old autohelm st50 that is probably original to thre boat. Faded screen, hard to read, etc. It appears that the gps may not be functioning. It does power on, but it just says "lat -" for latitude, with no value/degree stated for latitude, and the same for longitude, just says "long - ". So my question is, would a malfunctioning gps cause the st7000+ to give the seatalk failure error code, i.e., is the gps the reason the autopilot is not working?
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
It might be a cause. bypass it, and see if the autopilot functions. Seatalk more or less daisy chains everything and depending on where the gps resides in the chain, it could be the culprit. Double check all of your connections.Just because they look good does not always mean they are. Also, I would think that there should be a separate power source for the autopilot and that it and the instruments should work independently.
Apr 27, 2010
968
Beneteau 352 Hull #276 Ontario
Electrical Diagnoses over the internet is difficult.
The ST7000+ control head connects to the course computer through the SeaTalk connection. The course computer has the Gyro,Fluxgate Compass, and Rudder sensor connected to it, as well as power.
The GPS goes to the ST50 and is not part of the autopilot system.
If you disconnect the Seatalk connection that goes to the ST7000+ from the ST50 , your St7000+ autopilot should work all by itself. The St50 may go dark depending how power is being supplied. Usually power is transmitted through the Seatalk buss.
What is the error code??
rdees
Oct 5, 2011
14
Thanks. the only error code is "seatalk failure".
This is the description in the manual:
SeaTalk Failure​
SEATALK​
alternating with FAILURE
This silent alarm indicates that the SeaTalk bus is not operating​
correctly. Can only be cleared by rectifying the fault.
Apr 27, 2010
968
Then I would disconnect the ST50 SeaTalk connection to the St7000plus and see if the error goes away. If it does, then the problem is with the St50 system, if not then it will be with the ST7000+
Good Luck
586
If the work suggested in the previous post doesn't work call ray marine tech service. I have found them to be very helpful.
Beneteau 46 Georgetown YB
I had a similar problem last summer. No auto pilot and a Seatalk failure on the AP screen. I spent the better part of a day trouble shooting and ultimately narrowed it down to the GPS antenna (Raystar 125). If you go to the Raymarine website they have a Q & A section to assist in troubleshooting.
http://raymarine.com/knowledgebase/index.cfm
I replaced it with the newer Raystar 130 and also had to use the Seatalk to Seatalk ng converter. I had the system back up & running in a morning once I got the new parts.
Good Luck
DH
Sep 6, 2011
10
Beneteau Oceanis 373 Starr, SC
I have a Beneteau 373 that is outfitted with the same equipment. I too had the same message a couple of months ago. Prior to purchasing my boat, it was in salt water, but she is now in a fresh water lake. To rectify the problem, I applied dielectric grease to the electrical junction unit where the seatalk connections are plugged in. I haven't had any more error codes.
