Autopilot problem
zrod
Apr 2, 2011
26
Beneteau 43.3 Beirut
Hi,
Today i noticed a new problem on the autopilot of my hunter 340 -1999.
I could hear a strange noise while adjustment occurs, like a lose belt on a wheel. Also sometime, adjustments could not be completed.
Does anyone knows, if there are parts that should be maintained in the autopilot, or belts to be checked or replace.
Thank you.
caguy
Sep 22, 2006
4,004
Hi,
Thank you.
I don't know what kind you have but I rebuilt my ST1000 with a kit. It came with new belts and metal gears to replace the original plastic ones. Doesn't slip any more seems much stronger. Good luck. I found the kit on EBay.
zrod
Apr 2, 2011
26
But i think that the problem is in the wheel mechanism, not in the autopilot itself, as i can hear the motor of the autopilot working.
zrod
Apr 2, 2011
26
In fact, i found in the rear of the wheel a knob that allows you to calibrate the grip of the autopilot on the wheel.
I adjust it, and now things seems better.
Thank you for your assistance
Hunter 31_83-87 Charleston SC
My Autohelm started making noises as the belt began to fail. I found a place that sells the exact belt. Runs like a charm, again.
PolyBelt.com autopilot drive belt (part no. 973 340 1390)
