Autopilot Installation
K
Ken Delson
HELP! I am trying to install an autopilot on my Oceanis 323. There is no room for the rudder position indicator sensor OR the electric drive motor and arm. Can a wheel driven autopilot be installed? If so, what are the specs? What brand? HELP!
tweitz
Oct 30, 2005
290
Beneteau 323 East Hampton, New York
Autopilot
Our 323 came with an autopilot installed at the factory. It is the Raymarine which has a rudder position indicator built in. What kind of unit are you trying to install?
Doug_Meyer
Raymarine in mine
I have a hydraulic Raymarine autopilot that was installed by the dealer. The was the factory recommended installation at the time, and Beneteau evidently provided the necessary bracketry for the rudder position sensor ( mounted upside down intentionally). This setup was used because it was thought that the raymarine wheel unit would not work with the swinging wheel pedestal. I understand now that there is a way to adapt the wheel pilot to this.
tweitz
Oct 30, 2005
290
Raymarine
Ours is wheel mounted, even though it is the pivoting wheel.
Sep 4, 2005
40
Beneteau 343 Seattle
Wheel Pilot
Got a Raymarine wheel pilot (st4000) on my 343. Needs some special bracket that mounts the wheel pilot motor on the axle of the wheel to deal with the pivoting whell issue. I think that's a Beneteau part.. check with them. Rudder position sensor is just forward of the quadrant in mny case. Dealer installed it but looks straightforward
I
Ian Johnson
Auto Helm Beneteau 323
Hi I am awaiting delivery of our new Beneteau 323 . Ordered it with the Autohelm as it has a Lift Keel and twin rudders . Looked at the wheel mounted one as a dealer fit but they said you need to carry spare parts incase you strip a gear . You also have to disengage the autopilot drive when you want the wheel back , this is how you strip the gears by forgetting . They modify the attatchment bracket to work with the rotating wheel . Happy fitting Regards Ian
tweitz
Oct 30, 2005
290
Good luck Ian
Our 323 is fitted out like yours and we have enjoyed it a great deal. happy sailing Ian.
Jul 21, 2007
8
- - Ipswich ( UK )
Long Wait
Thanks . Been a long wait . Launch date 11th August . Its horrible not having a boat to use but then its not stopped raining for 2 months :-( .. Happy Sailing
