C
Chuck Wolfe
Since last August I have been going through grief with my Autohelm 4000+. It always suffered since it was only recommended for 16300 disp boats and the 37.5 is 16500 and mine actually weight 18000 on the slings when I had it surveyed. I worked sort of okay until last August when all of a sudden it started to veer off course and the degrees it read changed with the sun, the stars and the moon. I could use it in Track Mode and it would keep a course once I set it in Auto Mode but ocassionally it would start to turn X degrees, all on it's own, It got progressively worse. Autohelm has had the head 4 times and the last time they claim to have upgraded the software and put in a new system board. Well, it still screws up intermittently. It will work in track mode for 3 or 4 hours, then it goes nutz. I can put it in standby and all of a sudden I get error messages such as "off course" or "large xtrack error" or Seatalk error (cute-since I disconnected Seatalk based on Autohelm's recommendation. Even when it sort of works, it doesn't hold a course as well as it used to (snake wake heaven) and the motor is hot enough to fry eggs on. Any suggestions! I've consulted with Autohelm till I've been blue in the face! ChuckWolfe@mail.com
