I just bought a Rule Automatic bilge pump, and I'm a bit concerned about the way it works. Apparently it detects water by running a bit and checking for resistance. Now, the bottom of my bilge is fairly small and I have quite a long run for the outlet hose (about 10 ft), so I can imagine the "backwash" of the water in the outlet hose coming back into the bilge when the pump stops to be enough to present resistance, which will start the pump again, which will fill the outlet hose, which will drain back into the bilge... and so on.
Unless these pumps have a check-valve to prevent this from happening (which I haven't ever seen in a bilge pump in 40 years). My calculations say the backwash will be about 1.6 litres.
Does anybody have experience with these pumps, especially with a longer outlet hose?
druid
"Wind Drift" Ontario 32
druid
