Autohelm ST 4000
65
Hunter 31_83-87 Middle River, MD
We noticed recently that our Autohelm, when engaged, turns the boat in a big circle, instead of holding a reasonably constant course. Noticed also that the flux gate compass readout doesn't change with changing heading. Any suggestions as to what is happening would be appreciated. *o
Mitch
How about wiring
Sounds like the flux gate unit is not sending data to the control head. When in standby mode, the compass heading should change. Could be wiring. Wire routes, and connection in back of unit. What happens if you "turn the boat" to set the autopilot as per manual set-up instructions?
Jun 2, 2004
252
hunter 260 Ruedi Res.
have you added anything near the fluxgate
compass that could interfere? Ferrous metal, stereo speakers, wiring, atomic particle accelerator?
Jan 11, 2004
65
Thanks
Thanks for the advice. I will check out the wiring and hopefully it's a simple fix. And the atomic particle accelerator is mounted in the v-berth, so that shouldn't be an issue!
