Autohelm ST 1000 Question
Steve
Any owners of a 1995 Autohelm ST 1000 who still have the owner's manual? I need to know the procedure to switch the unit from Port steering to Starboard steering. I checked a newer model owner's manual that said to hold down the +1 and the -1 for five seconds, but that dosn't work on my model. My model the the one without a digital display.
K
Ken Shubert
How 'bout Autohelm?
Have you tried: http://www.autohelm.com/support/index.html This should bring up a form to fill in. There's also a 'FAQ' page. Oh, the powers of cyberspace! (Let us know if it works.) Ken S/V Wouff Hong
Mark Sanford
Autotack Function
I have a Autohelm 1000 and to initiate a port tack I must press the -1 & -10 keys together at once. Similarly, the +1 & +10 keys pressed will give a starboard tack. Hope this helps.
Steve Wright
The Answer
I talked with Autohelm, the looked up my model and the answer is: On the bottom of the unit is a small screw in the center of the unit, remove that screw. Then using a smaller screwdriver inside the unit trun small screw on the CO board inside of the unit. Lastly replace the screw in the case. Now the unit works on the Starboard side of the tiller. Thanks to Autohelm Service.
