Autopilots
I'm not aware of any choices you have on the 380 other than a rotary drive Autohelm. I got on the Autohelm web page and used their autopilot selector to see what they recommended. It said the 5000 was the correct so I went to Boater's World and ordered a 5000 Sailpilot. It arrived with a linear actuator. It WOULD NOT fit!!!!!Well, maybe it would, but you would need to use a chainsaw for the installation.We called Autohelm and got were advised that we needed the type 1 (rotary) actuator. I ordered this thru Boater's World but they were back-ordered for about 6 weeks. When it finally arrived it had a galvanized sprocket and standard chain. I wanted stainless steel.I ended up driving to Alachua and picked one up at the Hunter factory. I knew it would be the right one with all of the right parts. The 5000 is what they recommend for the 380.As for my original problem with no documentation:Early, Monday morning Joe Kerr(in customer support at Hunter) FAXed me the necessary pages of the manual. I have really been happy with Hunter's response to the little things I have needed help with.I still haven't had the boat out of the slip so I can't tell you how well it works. The physical installation was pretty easy and straightforeward. Except...Remember those strings your salesman told you about that would make it easy to run additional wiring? The strings were securely taped in the wire bundles and were useless to me in running the additional power lead. The wires go through a convoluted tube below the pedestal and it looks like the factory used 5200 to seal it up. Wait 'till you try to pull your power lead thru there!!You don't really have any options. I used K-Y jelly to lubricate it and pulled back and forth enough times that it finally cleaned out a passageway big enough to pull the wire thru. I removed most of the sole so I could see where to run the wires. I can't tell you any shortcut. Running the power lead from the circuit breaker above the nav station to the inside of the steering pedestal took me more time than all of the rest of the installation combined. Good luck.
