A
Aldo Lozano
I just installed a Autohelm 4000 and is working fine but for the dragging and jumping of the whell when I try to steer with the pilot desengaged or off.It's not the pedestal pin being out of aligment, because even not attached to the wheel the housing with the motor goes smooth in one direction but jam in the other.I haven't attempted to open the cover yet. Anybody had the same problem and, if you open the housing, how you did it? (Buried set screws?)The system works fine when is engaged, but when is not, sound and act like some gear is loosed or broken inside.Any sugestions?Thanks!!!Aldoalozano@monmouth.com
