autohelm 4000+ problem
John
Jun 3, 2006
803
Catalina 36mkII Alameda CA
Over this last weekend, I had a repeat of a problem I'd had before with my Autohelm st4000+ autopilot. The lever that engages the motor to the wheel would flip up (disengage) regularly. Has anybody else had this problem? Anybody have any idea what could be causing it and whether it can be repaired or if I need to junk it? Thanks.
DanG
Jun 29, 2009
14
Tartan 33R Mexico
That is a common problem with the 4000. On the back of the wheel, next to the lever is a small plug. Under the plug is a hex screw. This adjustes the belt tension by turning a roller that is on a cam and may help. You might also consider a new belt. If those fail, a small bungee cord is usually all that is needed to hold it in place.
John
Jun 3, 2006
803
thanks
Thanks, Dan. I just installed a new belt. It seemed to have plenty of tension when I installed it, but maybe it's stretched a little since then. I'll give that a try. By the way, does anything inside the ring need to be lubricated? If so, with what sort of lubricant?
Nov 23, 2009
437
Beneteau Oceanis 361 Clipper --
No, don't lubricate anything. You can clean it with fresh water for any dust or salt next time you will disassemlble it but I wouldn't recommend any kind of lubricant (especially mineral based such as WD40) on the belt.
