Wiring not there...
Although the breaker is labeled, there are no power wires run to the pedistal for the autopilot. They are a bit of a pain to run, but it can be done. Make sure you have an extra body to reach into the pedistal as you are pushing the wires up from below. A snake comes in very handy for this. Also, make sure you run the fluxgate wire at the same time so you don't go through this twice.I mounted my fluxgate under the galley locker. It kept in the middle of the boat, and there were no large metal objects around it. The cable from that can be run back through the bilge.I also bought the flat pin to lock the wheel in, but I have heard that others haven't and don't have a problem. I would say now that it isn't needed. Last item: If you will ever mount a GPS on the pedistal, you might get the flush mount display for the autopilot. I did taht ans was able to mount it low and still put the RayNav 300 above it. With the fluch mount, I could still get the drink holder and trash can out.Good luck,Steve
