autoprop
I have an H410 which I installed an Autoprop this summer. I replaced the factory 2 blade prop. The increase in performance was incredible. At 2000 rpm, the boat speed increased by 1-1.5 knots. I'm assuming fuel economy increase proportionately. Acceleration and back down are equally awesome. The boat will turn inside itself. Under sail the shaft needs to be locked (put it reverse) to feather the prop. The only item that took some adjusting to was slowing the boat. At an idle the boat will maintain 2-2.5 knots and nothing less. To slow the boat you have two options. Put the boat in neutral, and the prop will act as a drogue and quickly slow the boat. Alternatively, shift to reverse and give the engine a "burst" of rpm to change the prop to reverse pitch. If you don't goose the engine, the prop takes a while to reverse directions. Once I compensated for this, it's made pulling into a slip or onto a mooring a dream. Additionally, one can actually control and steer the boat in reverse. I feel its been a great investment with a dramatic increase in performance.S/V SpellbinderWeymouth, MA
