Auto Pilot
Jul 17, 2011
21
Beneteau oceans 321 Saint John
Considering installing a Raymarine wheel pilot on our 1997 Beneteau 321. With a Whitlock
Wheel / pedisal.Has anyone done this install?
Any tips to make install go smoothly.some back ground info will be tieing into a new
B & G backbone system
Thank You
Gunni
Mar 16, 2010
5,937
Spend the money and do the below deck drive system.
Oct 6, 2010
119
Beneteau Oceanus 321 Carters Pt.
Don’t think there is enough room between cockpit floor to mount hardware on rudder head
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
FYI I bought a complete wheel pilot from Defender. It didn't work because the software needed to be up graded. I don't know how you can check this before installation but if it doesn't work that is probably the reason.
@Sailm8 the assumption is the software needs to be updated.
The question is how?
Answer,
  1. ask a local dealer to upgrade using a Raymarine chart plotter.
  2. Ask a friend who has a Raymarine Chart plotter
  3. Buy a Raymarine chart plotter
Jan 21, 2009
260
Catalina 30 Lake Perry, KS
I sent my ev100 back to Raymarine this winter for a software upgrade since I don't have a plotter. They need the "compass", computer and control head to reprogram. Pretty quick turnaround and no charge other than my shipping cost to them. Waiting for spring to see if there is any improvement. Nor sure if it will ever be totally accurate without a rudder reference but I have no room to fit one.
Sailm8
Feb 21, 2008
1,751
Since mine was under warranty I sent the works to Raymarine on their dime. Fast turn around, 8 days.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
I have a 323 which is similar to the 321. Hydraulic pump is mounted in the lazarette, Hydraulic cylinder is through-bolted to small stainless steel plates on the transom with the rod end on the steering quadrant. Rudder position sensor is mounted “upside down” because of space restriction, and the port/starboard inputs to the course computer are reversed.
The setup has worked well for the 14 years I have owned the boat. I don’t experience nearly the amount of autopilot “hunting” that I have observed on other’s boats.
