If everything else is Raymarine......
....and is communicating to each other via Seatalk, you may need to install a Seatalk to NMEA interface. But this is not absolute - depends on your Raymarine components. Look for NMEA inputs on any of the Raymarine components and connect your AP 0183 in/out there. If they, in turn, are connected to each other via Seatalk, you may be OK.NMEA is NMEA. Unless you have pretty new components, they're all NMEA 0183. New stuff - if the manufacturer has made the decision - may be NMEA 2000 compatible. But NMEA 2000 is supposed to be backward compatible to NMEA 0183, I think.Dave, S/V Pas de Deux, Catana 471-44
