Attwood shower sump pump
Nov 16, 2007
19
Hunter 49 kent island, md
The Attwood shower sump pump on our Hunter 49 still sometimes works but I would like to replace it with something more reliable. Any suggestions?
Thanks.
Jim D
Dec 10, 2007
139
Hunter 410 Maryland
i just replaced both fwd and aft pumps on my 2001 410. fwd sump area was tight and i found this unit to fit. it works fine. at wm.
j
JOHNSON PUMP Multiple Port Shower Sump
Model # 10204204 | Mfg # 57151
Jun 1, 2009
1,830
Hunter 49 toronto
Get rid of sump box
Thanks.
Put in the Whale IC grey water pump with T fitting.
This is a much better system.
Sep 12, 2005
34
Hunter Legend '45 St Claire Shores
Jayncee,
I replaced the old Forward Shower sump pump on our 1988 45' Legend with a Seaflo Automatic Submersible Boat Bilge Water Pump 12v 750gph Auto with Float Switch that cost us $21.
It fit perfectly, didn't need a separate water float switch AND!,...it drains the waste water level in the shower sump down to 1/3rd the water level of the old arrangement. Which thrills my wife to death, because the remaining (residual) water can be mopped up with just a towel now.
Regards,
James
Jun 4, 2004
292
Hunter 49 123
I would put a few grams of Bromide tables every few months. I found that if not runned often I find some growth that locks the float. I have been removing the growth by hand (which you may have to do anyway) before I started the bromine regiment. I also run a few gallons of water just tomake sure its working.
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
We have the Attwood shower sump box and pump for our shower. The pump died and Attwood do not sell a replacement fir this pump. I just purchased a Whale diaphragm pump from Defender, last week. It was a significant saving because of a discount through Activecaptain. It looks like a much better pump, does not require a filter of any kind.
Here is the link,
http://www.defender.com/product.jsp?path=-1|51|2234226|2234234&id=1777934
The list is over $200, we bought it for $130.
Bob
Sep 11, 2011
421
Hunter 41AC Bayfield WI, Lake Superior
I replaced all of my ITT sump Pumps, on or 2004 H41, with Whale Gushers. Best thing I ever did. NO MORE MAINTENANCE. They just work! A sump pump that needs a filter is just wrong.
