Attn: 49 & 50 owners
Jun 1, 2009
1,837
Hunter 49 toronto
For those of you who haven't had the pleasure of doing so, changing the engine water pump impeller on the Yanmar 4JH-HTBE is a 2-3 hour job;
And that assumes you are sitting at a dock. In rolling seas it would be almost impossible.
Good news:
I've come up with a method to change the impeller in 15 minutes.
I'm working out the details of it, and will post a document once it's done.
The only thing slowing me down is some recent knee surgery.
Once I'm healed, I will be good to go with this.
So, help is on the way.
Jan 10, 2012
75
HUNTER 49 MARINA DEL REY
Very easy to pull the impeller if you have the Yanmar impeller puller ($15). Just move the alternator out of the way.
Jun 1, 2009
1,837
Hunter 49 toronto
Moving the alternator
Is far from a small job . Is it's not moving it; it's removing it.
Have you done this yourself?
Btw, the yannar tool is. Jackscrew.
You need excellent access to the rear.
Plus, only I works on Yanmar ; not johnson impellers.
KD3PC
1,069
boatless rainbow Callao, VA
I use the mirror method and a bright light, once you get used to everything being "backwards" it is not too bad.
For sure, would be much tougher in rolling water or a channel. I switched to a speedseal cover on my second seasonal change and never looked back, can almost do it by "feel"
IF you have a spare water pump, it can be easier to swap the whole unit out and then R&R the impeller on the bench. Fewer bolts, but more mess.
Ah, the joys of owning a sailboat. But think of the $200-300 you save by not having the yard doing it and you - KNOWING how it is done, just in case.
Jun 4, 2004
292
Hunter 49 123
I replaced the pump cover with Speed Seal and use a puller no need to remove alternator. you do have to remove the engine cove which is a pain....
Dec 2, 1999
15,184
Bent nose pliers are a big help when r/r the impeller.
We were able to cut an access panel on the port side of the engine compartment which was a big help on our HV'36.
Jun 1, 2009
1,837
Hunter 49 toronto
No way with boat rolling
Working backwards with a mirror, etc., is fine when the boat is dead still.
Even so, there is no way to get around the alternator with the engine sub-floor.
One of the things you should do, (until I publish my fix), is to use socket head cap screws for the cover screws.
That way you can load the screws onto a super-long Allen key, and not lose the screws in the bilge.
Another trick with socket head cap screws is to put a single wrap of masking tape around the screw head to keep it attached to the Allen key. Then once it's partially threaded in, pull back the Allen key & the tape comes right off.
The pump location on this engine , (facing backwards) was a huge oversight by a Yanmar. They have corrected it in their latest engines
