Attachment Point for CDI Roller Furler on H26 WB
K
Kevin Flanagan
Can't remember attachment point for CDI Roller furler on H26WB. Have 2 choices..Flat SS that extends above the deck or round SS that resembles an "eye" or "bight" that's about 4 " lower than the deck. Didn't see any mention in the owners manual. Can anyone help? Thanks !!!
C
crazy dave
ok this is what I do
kAttach the furler in the forestay chain plate in the hole close to the cockpit.
A
alan
If I understand your question correctly...
...it attaches to the pad eye (u-shapped fitting) at the bow. However, if you have a 4/6 drum then you need a length of a pair of tangs (flat steel with holes)to extend the drum above the deck or it will not fit. In addition, the forestay needs to have been shortened to make up for the additional length of the tangs. From my readings here and looking at my own boat this was not done in many cases. A size 2 drum fits without the extention (at least in the 260 which is a little different). The flat steel fitting I have been told is for the tack of a hanked on head sail. alan
Dick
Confirm
Alan's comments agree with the installation of the CDI II on my 26WB.
C
crazy dave
Dick I was wrong
I was thinking of the 260. The 26 if your has the roller furling should have two tangs or metal straps and they attach to a u bolt or pad eye on the bow of the boat. Sorry about that
K
Kevin Flanagan
Thanks fellas
Appreciate you guys jogging my memory. I attached the SS plates to the u-bolt and it "all came back to me". Thanks again !!!
