Attachment for boom vang
K
KennyH
Could someone with a boom vang on their hunter 25 give me an idea on fittings. I have the vang but there no connection at the bottom of the mast. Also what type of connection to the boom is normally used? This is the regular block and tackle boom vang.
Jun 4, 2004
844
Hunter 28.5 Tolchester, MD
Boom Vang 'Yokes'
Check out WM for stainless steel 'U' shaped yokes. Measure the width of the boom for the open end of the first yoke; drill a hole for a 1/4 or 5/16" thru bolt on the centerline of the boom a distance back from the gooseneck about 1.5 times the height of the bottom of the boom from the deck. Add the second yoke to the thru blot that attaches the mast to the mast base tabernacle; connect the boom vang to the two yokes with the operating becket on the lower end so you can snap the line down out of the cams.
