So I have an arch on the back of my 26S made of 2" aluminum tube, and the idea is to use it to support all sorts of "stuff" on the back of the boat. There are a couple of lifting applications where I would like to attach padeyes to the aluminum tubes for swivel blocks or snatch blocks, and there may be "some" load when lifting things with them. (Can't define how much load...but reasonable weights should be assumed...raising the motor, raising the rudder, possibly holding a small dinghy, etc.)
Obviously, i want the padeye to face down, with the loop underneath the arch to hang stuff on. This means that the fasteners holding the padeyes will be under the arch and all the load will be pulling down on those fasteners, at least if I use a standard 2-hole padeye. So what kind of fasteners should I use? Rivets? Sheet metal screws? I don't feel comfortable with those, but didn't want to have to drill all the way through the tube with a 2-1/2" long bolt just to mount a padeye. Maybe I should just suck it up and do that? Any advice?
I'd like it to look clean at least, and even thought of using rope to lash them in place so it would also look nautical. But I didn't want to start there... Ideas?
