The way it is done
on your boat is the correct way.On my boat it is with Presslock shackles. That may not be correct for your boat.There are several ways to attach sheets to headsails, pick one that works for you, it will then be the "correct" way for your boat.
Every main sail I've ever seen that uses a boom is attached to the boom. Loose footed mains (like on some multi-hulls) don't have booms, and are therefore unattached.
As far as boomed sail being attach only at the clew or along the entire length of the foot. It makes no difference to sail shape, or speed. On a "loose footed" sail it is easier to run reef lines. "Loose footed" sails are poor at catching rain water. You can perform a mail slot spinnaker drop in heavy air with a "loose footed" main.Isn't it still warm enough in Tampa to be out sailing? Why are you asking "it's winter and I'm bored out of my mind questions", when you could be out on the boat trying different ways to attach jib sheets?
BTW- If you look in the archives you should be able to find more that one debate on this very subject.Randy-Suffering from "It's winter and my boat's been out of the water for 13 months and I'm bored" syndrome.
