Hello there,
I'll continue to pick the collective brain of this fine group, this time on the subject of how to attach a VHF antenna to the mast of my vega, and running the coax cable down the inside of the mast and into the cabin.
As the mast is currently up, so I've been thinking about either getting up there in a bosun's chair, or moving the boat next to a mast crane and attaching the antenna from there.
So, any tips? Do I have to make a new hole in the top of the mast for the coax, or can I use the hole that's already there for the sheets? What about inside the cabin, have you used a two-part cable, where the coax inside the mast just comes out of the bottom and is then connected to another cable that runs to the radio itself?
Mikko
Mikko
