tracy
I'm tuning up my 1979 atomic-4 on my Catalina 30 (new points, cap, rotor, plugs and wires) and I was wondering if I have to re-time it.If so, can I do it without taking off the flywheel cover? is the timing mark (pin) on the cam visible where you hand crank the engine. If it is on the cam, should I cut or drill an access under the dining seat since there seems to be only a couple or inches of room? THANKS
