Atomic 4 strange behaviour
Aug 17, 2013
1,097
Pearson P30 202 Ottawa/Gatineau
Hello everyone
I already asked this on the Moyer forum, but no answer, so here goes
I just got my timing and RPM’s adjusted on my old atomic 4, it used to run way too fast, and minimum speed was around 5 knots in gear.
Now, I am happy to say I can coast at just a bit over 3 knots, much easier to dock
before the adjustments, whenever I took it out of gear, the boat slowed down really fast, now she take a lot longer to slow down, I like it, but I simply don’t understand the reasoning behind this new behaviour, could it have affected the transmission? We did not touch it at all.
I will try to look at the transmission when I have time to go back to the boat, but I would like to know what to make of it and where to look beforehand.
thank you all so much
1,097
Did it in the water, so no, nothing except the tuning of the engine has changed
Nov 6, 2006
10,155
Off the wall observation :
Might be a perception thing? Previously, with too much idle RPM, you went to neutral and then reverse to stop .. now you let it coastmore in neutral..?? I dunno.. NO, I am not in the rum yet today.
Floding or feathering prop now going to low drag at lower RPM?
Aug 17, 2013
1,097
Before I was coasting at around 5 knots, when I put her in neutral, I did not even do 50 feet before doing around 2 knots, now let’s say I am doing 4 knots, then shift in neutral I do over 200 ft before I start to really slow down . I usuall Had to put back in forward to be able to dock, now I don’t loose enough momentum to stop before the dock, I actually have to put her in reverse.
again, I am really confused about this
Likes: kloudie1
Aug 17, 2013
1,097
I wish I could begin to understand it before put a patent on it
I am just wondering if the lower idle speed could affect the way the reversing gear works
I know the at before when putting in forward, it sometimes slipped and not engage, so maybe that has to do with it???
7,605
Alden 50 Sarasota, Florida
Eureka!
what slips when engaged also slips when disengaged
Aug 17, 2013
1,097
It doesn’t slip anymore, so I am not sure how to figure this one out?
It engages more easily now, and I do feel it go to neutral, could it be that before it partially engaged reverse and that was what was slowing me down?
I am still waiting on ans
It deserves a few more open water tests before you get too excited. On a calm day take it out and run at various speeds, maybe 4 different RPM’s.
Idle
1/4 throttle
1/2 throttle
3/4 throttle.
With a fixed mark (buoy or float with an anchor) quickly reduce power to idle and take it out of gear. This should give you a better understanding of you coast (drift). From 1000RPM’s I found my boat can coast at least 40-50 yards, with steerage.
I use that knowledge to get into my slip without incident.
Jan 4, 2006
7,452
Can you elaborate on what you mean by adjusting the timing ?
Did you have problems with the timing and what is it set to now ?
1,097
We noticed the timing problem when we tried to adjust the idle speed, it would shut down when trying to adjust, even at high idle.
we adjusted the distributor, when we looked at it, it was all loose, so out of timing, by following the instructions on the Moyer site we adjusted it (can’t use a timing light as there is no TDC mark )
Check the adjustment on the transmission cable. It may not be fully disengaging in neutral or it may be partially engaging in reverse. This would account for the rapid deceleration when the idle speed was too high and slower deceleration with the lower idle speed.
Likes: fred1diver
