Concerns, yes, but information is more important
To a large degree, the state of your next Atomic 4 is going to depend on its upkeep over the years. The production run on the engines ended sometime in the early to mid 80's, so any A-4 you find will be a minimum of 15 years old. Properly maintained, the engine will run 20 or 30 years, sometimes more. Improperly maintained, or worse yet, neglected, the engine will not last a decade.Click on the link below for some good information on the engine, and links to its history. Briefly, the engine has been produced since about the 40's, with very little modification. It is overbuilt, and overpowered for a catalina 27 - an great attribute and a strong argument in its favor.Get a surveyor to inspect the entire boat for you, including the engine. This is the best $270.00 you will ever spend. I have an original A-4 in my 1979 Catalina 27 and I love it. I was originally apprehensive about the motor, but have grown to appreciate its strengths, one of them being a whopping 30 hp, which is three times what you need to power the boat.With any luck, you will be sailing much more than motoring!Have fun doing your research!Best Regards, Rob
