After taking the carburetor apart and giving it a good cleansing I was finally able to revive my newly acquired A4 from its year and a half slumber. At anything above a low idle though I'm getting a horrible knocking sound, even after fine tuning the timing by adjusting the distributor body.
When I searched for some help, not much came up so it appears this is an uncommon problem with the A4. Originally I hoped it was just the low octane fuel I was using (initially I was running 87 since the manual said "regular" -- but later I saw they recommend 90-94), but today I swapped out the old fuel with some 92 and didn't notice a difference.
Along with the knocking I'm getting a lot of white/gray smoke out of the exhaust. I believe this is just the extra oil I added to the top of the cylinders burning off but I'm not positive (since the engine had been sitting unused for so long I put two teaspoons of oil into each cylinder and turned the engine over a couple times by hand, as recommended by the manual).
A lot of the advice I found on engine knocking said it's likely due to carbon deposits and that the best way to fix is it to take the engine out at push it hard to burn the junk out. Seems like a risky thing to do if carbon deposits don't end up being the source of the problem.
Any ideas what might be causing the knocking or how to fix it?
