Atlantic Ocean Water Column Height
So 20 meter wave pattern?
And a trough of nearly 40 meters.
So you're saying.... Whoooaaaa,,.,, WEEEEEEEE!!! surfing every 15-17 minutes...
May 27, 2004
2,042
Aha, The Bermuda Triangle is REAL!
But seriously, Thanks for posting.
4,928
Pearson 37 Lusby MD
At least one of the surges was more than 30 meters - so that would be a really BIG WHEEEEE!!!!!!! :beer:
Mar 13, 2011
175
Islander Freeport 41 Longmont
This is the water column height, not wave height so unfortunately it wouldn't even be notice at sea, it's more like the tide change but since you are in open ocean, you don't have any reference to measure it by. Without the GPS on the buoy, it wouldn't notice it either. The flashing buoy's in the video are listed as Tsunami warning buoys activated after the earthquake.
Interesting data points and could be an issue if the height carries over to shore where it could turn into a Tsunami. And while the data points are interesting without a historical reference to see if this is normal or directly related to the earthquake its hard to understand what is going on.
JamesG161
Feb 14, 2014
7,754
Hunter 430 Waveland, MS
:plus::plus::plus:
This one shows the recent Quake ripple passing by.
Here is a nearby WAVE buoy and weather with a camera too.
NDBC - Station 41049 Recent Data
Wave height was 7.9 feet.
Waves are surface things. Water Column is a depth thing.
5000+ meters is a few miles of ocean depth being effected.
Tsunami are not a major problem unless they hit shore line.
Why?
The lower part of the "wave" is pushed upwards by land. In deep ocean, not so much.
Jim...
